Still struggling with the milk steaming
I am thinking maybe their is too much water in my steam?
When I hold my hand under it (at a small distance) it quickly gets soaking wet
I have a S24 with boiler set around 1.1bar I am looking for mechanical things I can do, I changed the tip to the 2 small hole as recommended by coffee parts guy, changed the 0 ring on the tip and keep everything clean. Maybe I need to descale or clean the steam arm?
I can stretch the milk about 30% and swirl it around and it looks really good, but goes flat in a few minutes
I have tried every possible way, I use the same milk the Lacehin uses and the right jug he uses and his latte's are fantastic.
So it is either my machine or my way of doing it. I did get it right once in a hundred tries though.
