From scratch roasters - worklog
So I had five hours in the car driving today, just me and my brain (horrible company!).
I first had the idea that I would add a third halogen heater to my Behmor, as I have access to a heap of lamps that get thrown out (photocopier tech), however they were too long to fit. I also have access to plenty of low speed DC motors.
I was in Big W this afternoon, and impulse bought two mesh 20cm garbage bins which will be perfect for making a drum out of once I've removed the no doubt toxic paint from them.
Before I get cracking, has anyone here ever built a roaster completely from scratch, and are there any tips mainly regarding airflow and heat position in relation to the cage? I will have either 6 or 8 lamps, individually hooked up to light switches. Also, any tips on how to "test" without wasting beans. I anticipate this roaster will do ~500g as the internals will be just a big bigger in size compared to a Behmor, but with an extra ~800W, and possibly better insulation. Will putting small holes in the bottom and top be enough for convection airflow, or will a fan be definitely required?
I plan on using just sheet metal and rivets to make the outside, and insulating with just an air pocket and/or fiberglass insulation.
Will get started tomorrow night if my lamp gathering goes to plan.
