Mazzer Kony doser 'chute'
I am interested in a Kony but before purchasing would like some advice on how well (or not) the doser system works.
Perhaps more specifically, I refer to the build up of ground coffee in the chute that some (most?) machines require before eventually falling into the doser.
Does the Kony suffer from this problem eg) at the end of a grinding session is there going to be a dose or two of ground coffee stuck in the chute thereby requiring removal prior to the next 'fresh' grind ?
If this is the case is the chute readily accessible for cleaning purposes without removing the doser unit?
Thanks for any advice
