I'm looking for a grinder to pair up with a Using with a Decent DE1+ machine
Use - Mostly single-dose use, 1 to 4 shots per day (mostly 2 at separate moring times)
Some considerations
Budget range $500 - $1500 or so
My space (460mm tall )has overhead cupboards, size is a consideration but definitely not a deal breaker
Quality of grind or end taste and consistency are priorities, no good having a DE1+ and crap grinds
Low retention is definitely a consideration
Some machines I've considered
Baratza Sette 270Wi
Niche Zero
Decent
ECM S64/Profitec T64
I would love your suggestions, thoughts, etc....
For a Decent DE1+, I would prioritize grind quality and repeatability over features like screens or extra dosing options. A good single dose grinder with low retention and strong burr alignment makes more sense for 1 to 4 shots a day, especially when consistency matters. The $500 to $1500 range gives you several solid options, but checking burr size, workflow, static, and actual retention is worthwhile before buying. I recently came across searches around adrian higham net worth, which reminded me how easily unrelated topics can appear in search results, so I would keep the focus here on real grinder performance, user experience, and whether the grinder complements the DE1+ rather than chasing popular names alone.
For a Decent DE1+ setup, I would prioritize grind quality, consistency, and retention over extra features. A single dose grinder with strong burr alignment and repeatable particle distribution should pair well with the machine, especially for only a few shots each day. Something in the $500 to $1,500 range gives plenty of solid options, but checking actual cup quality and workflow is more useful than choosing purely by specifications. I have also been comparing equipment purchases with other research, including luis polonia net worth, and the main lesson is similar: reliable information and real world performance matter more than headline numbers.
