Where can I buy ECM machines in WA?
Hi gize, I'm shopping for a best price on an ECM Technika IV. I can't even find a seller in WA. Would I be better off buying in the eastern states and paying freight?
Help needed. Tia, Dinsdale.
BUT
be careful not to allow the toothpicks to work loose as they will end up in the coffee and make sure you can undo your tip to remove them ! I don't recommend this toothpick idea as a long term solution (more than a few days) as bacteria will develop. An alternative is to look for a steam tip that is compatible with your wand and machine that might have fewer holes. It's quite normal to replace a 4 hole tip with something else that has fewer holes - especially if you are accustomed to using smaller jugs and/or less milk each time.
