Basic list of essentials.
Machine - well duh
2 group is best for most jobs not to heavy and can generally be wound back to
10A supply
Grinder - this needs to be MUCH faster than a domestic one or you will finish up in strife with heat and speed.
Bench top - if your setting up separate to existing benches then this needs to be very solid and have a sanitary top.
Permits - unless your trying to sneak in or the quiet then you need a local council permit to make and sell coffee.
Water Supply tank - budget 100-120ml/cup including a little cleaning up. So 20 litres with a spare is plenty.
Waste Tank - generally can be smaller at 10 litres but 20 will save a trip to get rid of it.
Slops Bucket - Milk slops and extra foam are best put separately rather than down the drip tray.
Extension leads - Heavy Duty ones, don't scrimp.
Power Boards - as above HD.
Fridge - Needs to be able to handle being opened and shut and keeping cold. Budget 120-200ml/serve for milk.
Jugs - 3-4 needed. dedicate one to doing Hot Chocs and label it that way. Also Temp stickers on each for consistancy.
Teaspoons - long handled ones 4-6 for mixing HC and all sorts of other reasons.
Cleaning gear - clean (separate) cloths for PF's machine and wands. Extra gear for other cleaning.
Knock box - floor standing one or certainly one that will handle 30-40 pucks (not a home one).
Coffee - consider decaf as well if it is a night time gig.
Hot Chocolate - seriosly good money and depending o the crowd 10%+ of turnover.
Milk - low fat and full cream in a 1/3 to 2/3 split will get you 95% happy. 5% Soy is about normal so optional.
Sugar - Bowls of sugar are the cheapest least rubbish inducing option. Consider offering Raw and White.
Chocolate shaker - and sweetened chocolate for caps (different to HC blend)
Marshmallows - forget these at your peril and frowns from all ages of kids to 60+
Cups - disposable only to keep it simple 8 & 12 oz. I still serve Espressos in ceramic as is proper.
Lids - if you don't offer them always you will only need around 30-40% to cups used.
Teaspoons - only offer disposables to save on health and safety issues with your permit.
Menu and holder to suit. Keep it simple clear and easy to avoid confusion on both sides.
Cashbox or bumbag for the $$. Double what float you think you need. You will get a heap of coin late in the day but you need to surrvive the opening $50 note barrage.
Notepad and pencil/pens for taking large or difficult orders (embarrassing to have to ask to often)
Textas and paper
Additional items.
Second Grinder - Decaf or even throw in a S/O to mix it up a little.
Cup Trays - box of 100 off evilbay for $30 is a good idea to have up your sleeve
Timer - check your shots once in a while if your outdoor grinders need to change all day.
Electronic thermometer for checking fridges - locally should be done twice a day.
Cable ties - keeping leads hoses and lots of stuff neat, never leave home without some.
Gaffa Tape - same as above just really handy.
Large Clothes Pegs - handy for clipping Sugar or Coffee bags closed (not all have zip locks).
Broom and shovel - spill beans or grounds you need one and searching for a broom can't be done if your busy.
Rubbish Bin - don't rely on ones provided in all cases end of the day may be overflowing.
First Aid Kit - slices cuts and the odd burn happen when your under the pump and rushing.
Trestles, Chairs, Umbrellas, Sunscreen - If your doing coffee your stuck for the duration so plan ahead with comfort.
That's a basic list of gear to kick it off. Anything else needs adding or you want to chat about any of the items on it then this is as good a place as any to do it. Several of us here have some to a lot of experience in running coffee carts and mobile coffee of various sorts so if you get asked to do a job say yes and have a go it's lots of fun to be had
Just on the list above while it may seem a little intimidating there is no reason you can't take your home tanked HX or double boiler along to a venue and make maybe 20-30 an hour but if you want to get a little serious then boiler volume and a couple of groups makes a heap of difference.
