behmor roasting question
so i noticed something interesting while roasting on my behmor
was putting a roast through P2/B on the behmor
according to the manual it says that p2 ramps up to 100% power to about 60% of the time and then drops the power back for about 30% of time
and for the last 10% of time ramps power back up to 100%
does this mean that the back elements should turn back on?
I was datalogging the temp change as well and noticed no increase in temperature before the program ended and went into the cooling cycle
the temperature drop was accurate @ 60% of time in but just didnt seem to increase from there and just slowly coasted to lower temps all the way to the end?
anyone else had the same experience?
  • Mine definitely does increase at that point, but not to 100% power. The elements don't go red hot, but there is definitely a "click" and the power increases (I haven't monitored with probe, but have put a power meter on the point).
  • hmm..interesting i shall listen out for that click on my next roast i just thought it was weird the temperature just kept plunging. not even stabilizing or a 1c increase at all what is your preference on programs richardm?
  • Answering that question is always fraught with danger, because every Behmor is different, and every power supply is different, thus, my profile preference (1PP2B for ~315g) might not work for you following the exact same method.
  • that's understandable it was more of a out of curiosity question :)
