BOWL SPOON A HEATGUN.
This is not necessarily how to get the best out of a roasting method or really even how to roast it is as much a primer to get in and give it a go without spending much money if any.
Beg or borrow a few bits if you don't have them and give it a bash the results may just surprise you
Entry level low to no cost gear:
Stainless Steel Bowl preferably high sided like the one shown, also rubberised base is good.
Sacrificial/dedicated Wooden spoon it will get blackened and pick up coffee oils. Another option is a stainless steel kitchen whisk, just watch the heat of the handle.
Kitchen Timer or better yet one as shown with a temperature probe as well
Roast Monitoring
Paint Stripping gun these days available cheap from a range of sources.
Oven or welding glove, spoons, bowls and strainers get hot at 200 degrees.
Kitchen strainer or mesh sieve for cooling.
Beans - see this forum section about what and where to get some
Green Beans from, don't worry to much about the range there is hundreds but if in doubt ask for an easy one to get going suppliers will know what to give you.
Before the roasting begins.
Start with 250-300g works best. To little and it's harder to roast evenly and consistantly, to much and they will escape over the sides.
Basic Gear ready to start.
Slightly high Tech, Kitchen timer with a Temperature probe just to help keep the roast in check. Not needed but worth it.
During the roast and what should happen and about when.
Generally the following times are a reasonable starting guide and ALWAYS the temperature should continue to climb throughout the roast. But as a rule of thumb 8-12 minutes to First Crack (FC) then 4-6 minutes to Second Crack (SC) or the end of the roast.
3 Minutes in and sitting around 100 degrees, colour isn't correct the beans are green to pale yellow.
5 minutes in and above 130 degrees. Starting to go from Yellow to pale brown. Moisture and a little chaff (like peanut outer husks) start floating around.
11 minutes in and post FC (Also refered to as RFC or Rolling First Crack) - the beans have given off a distinctive snapping noise along with losing a lot of any remaining chaff here. Also a little smoke starts to come off the roast. Also ease up on the heat a little at this point as they beans start to give heat back to the roast (Exothermic).
When to end the roast
This question along with the rest of the timings from above is worthy of a book or two and best discussed in its own thread. Basics are generally lighter for Brewed Coffee like Plunger or Darker for Espresso. Taken further than this roast the Beans will get to to Second Crack. Generally these are softer and may be a little hard to hear but this stage is accompanied by a fair bit of smoke and if you keep going FIRE :o 15-16 minutes I find is a sensible "start point" to roast in. This roast for brewed coffee was pulled at 15 minutes and just on 200 degrees.
This picture is of a few escapees from the bowl and are all generally before or just on First Crack. The most righthand ones you can actually notice the cracks formed on the bean but they are lacking any real colour yet.
Cooling
This is important to finish the roast at the point you want, heat within the beans or bean mass will continue the roast unless you cool them fairly rapidly. The Sieve above or Kitchen strainer is needed and best to agitate the beans or even blow air over them in the breeze or with a fan. Lots of roasters use custom built coolers for this task.
Post Cooling and a fairly even roast in spite of taking pictures along the way. It is important to keep stirring all through the roast and not use the stirring hand to take photos.
Storage
With your first few experiments unless you have a few coffee bags saved up or have purchased some for the job do the following until you get some. Please note ALL vacuum coffee savers are a bad idea! Freezers and fridges are also a generally a bad idea! The beans while resting prior to consumption they give off CO2 gas so a sealed Jar is potentially a danger so go for a heavy weight plastic bag with a wire tie and place them in a dark cool cupboard. This while not as good as dedicated valved bags is better than an open container and not dangerous like a jar and lid.
When to use your roasted beans
Another one of those contentious issues and it varies wildly depending on bean roast level and personal taste. Start with 4 or 5 days with most and experiment but some beans may need 2 weeks+.
As I started above this is not supposed to be comprehensive or the complete doctrine (several years in and I know relatively NOTHING
) on roasting but just to say get in have a bash, take some notes taste refine and do it again and improve.
