Lelit PL041EM Steam wand leaking issues
I've been asked by AM to post about issues with Lelit leaking steam wands, so just thought I'd do a write up on the last six months with this machine.
Upon receiving the machine, there was no leaking at all from the steam wand, but after about two months, it started leaking marginal amounts of steam, then by 4 months, it was dripping while the brew heater was on as well.
I pulled it apart, and found that the steam tap itself was pressing against the body, and not being able to tighten fully without turning VERY hard.
I filed the back of the inside of the steam tap back, and it allowed me to tighten fully, but still had a leaking issue.
I received a new steam tap shaft last week, and the new rods (at least the ones Jetblack Espresso are supplying) are around 5mm longer (so obviously, someone has noticed this.
Despite all this, I'm still getting *tiny* amounts of steam leakage from the machine, and fear it will start dripping again soon.
There is one thing that I would like to do and that is look at different (thicker) o-rings for the tap rod (they come with two o-rings) to see if I can get a better seal. The other option is, I *might* be able to squeeze 4 o-rings in there instead of the two, as there is space (and this might contribute to the issue, as the o-rings have the ability to move around a fair bit).
In reality, all this doesn't worry me much, as I rotate the steam wand over the drip tray until I need it, so any drips are caught, and it's certainly not enough to run the boiler dry, even if sitting for a few hours. As much as it doesn't worry me, I'm amazed that I haven't found any articles on the internet describing this issue beyond "I have an issue".
