One of the more difficult parts of the coffee making process. The actual process is easy enough to learn, but it is at this point that most people fail.
The interesting thing about the tamp, is that is irrelevant if the dose and grind are in perfect rainbow warrior power cosmic alignment. If you fail to tamp correctly. It just dont come out that good...
Now you'll get a good coffee most likely, but you might not and thats why correct technique is so important.
In my mind, there are 3 main factors in tamping (Assuming all other factors machine temps, grind, dose, etc. Are at thier optimum)
And I'll say before I begin. Stop bloody collapsing the grind by tapping the group handle on the bench before you tamp. This "WILL" assist in creating an uneven puck. Plus, if your a bench tapper/scraper (a foolish process), you wil NEVER get the same result twice except in a parallel universe. If you dont understand why, take a basic physics class and you'll probably get it. Sorry if that sounds harsh, but its just not a consistant method of dosing.
Ok.
Firtly, positioning
Stand facing the bench (practice without coffee for this bit) about 1 normal step away, your hand with the handle by your side. Place the group handle with the pourers against the edge of the bench, directly in front of where it was comfortably hanging by your side. Also its important to hold the tamp correctly. Ideally, the top of the tamp will be pushing up into the fleshy bit at the base of your thumb. Your thumb running strait down the stem to the base, and your first, second and third fingers wrapped around the stem. If the tamp isn't designed in a way that this is possible, then as close as possible.
Now turn your hips 45 degrees to the bench, with the tamp hand make a 90 degree angle at your elbow and put the tamp over the handle so that the tips of your thumbs are facing each other. You should be leaning slightly over your group handle. It will feel natural, and your face will most likely be toward the floor. The important thing about your arm is that it is directly veritcal to the handle. This will ensure an even tamp.
Now we have our stance worked out. The tamp.
You'll need coffee now...
So assuming the stance, in one clean and clear motion. Lean "NOT PUSH", on the coffee. Lift your leg and use your body weight to do the work. Whats important here, is to feel the pressure trasfer into the back of your shouder (scapula). If you feel tension in your hand or forearm, it means you are gripping the tamp and pushing with your arm. Avoid this, mostly because the tamp will be inconsistant, but may also lead to RSI or Carpul Tunnel. The important thing to do here is to keep your arm at 90 degrees the whole time. Now after tamping down, as you lift do a twist to polish the top. Now, give the group head a decent whack or two with the "back" end of the tamp (if you use the side or front of the tamp you'll damage the integrity of the tamping surface and coffee will get caught in the grooves, you dont really want that). Repeat the process, but put just a little more of your weight on the puck (remembering not to push) and focus more on the polishing of the top this time, that or do a third light tamp mostly for the polish.
Thirdly, and not so much an action, is that all of these actions should feel natural. At any time you get sore, or the action hurts somehow. Go back over the method set out above and work out what your doing wrong. Essentially I've set out an ergonomic tamping method.
A bit of back story of me. I have studied dance, physical therapy, concious body work and oseopathy. I have been professionally making coffee for 8 years and have been teaching for 2 years.
