Krillian, The best coffee you will make with the MD is when: a) buy best quailty fresh roast coffee...not black or oily...should be cinnamon coloured roast (which should mean a high quality oz style espresso roast) b) set the doser lever inside the door to 1 notch larger than the middle position, and perhaps 2 nothches dependent on coffee beans...autos need a large dose. Some may even set thing on the maximum dose, but i dont like the character of wet coffee produced with an overly large dose. c) grind is dependent on type/density of coffee, and the dose you have arbitrarily set above, but these machines are not really designed to be run on the finest setting ie you will probably find that the wet coffee does not taste as good as it will be if you you back off the grind to the second or maybe the thrid from finest setting...this one is entoirely depoendent on the charactr of the coffee you are using, and what you as an individual like in coffee. The oft quoted "rules of espresso" do not apply to Autos so my advice is
