I would love some advice in setting up my machine/grinder to help perfect my espresso making ability.
My dilemma is understanding the cause/effect relationship between grinder and machine. I am using a single group Wega MiniNova semi-auto machine and Ibertal grinder (which has a worm drive allowing infinite adjustment) and always use the double filter holder filling the basket to the top with coffee, levelling and then tamping.
With regards to grinding/dosing I am not one to get out the scales and weigh the correct amount of coffee, tamp to 30lbs and run for 28 secs and measure the precise amount of espresso in the cup. Instead I have let the quality of the "pour" guide me to let me know if the grind is too course/fine or the tamp too light /heavy. What I look for is a nice thin golden brown stream that tapers towards the cup turning off just when I notice a slight change in colour. Usually I observe "tiger striping" and the "Guinness effect" but am not sure if these are indications of correct method or just type of beans used?
I have also adjusted with the pressurestat to see what difference that has on the extraction (dropped from 1.25 bar to 1.1bar) and noticed due to the reduced temprature the crema becoming much lighter than the usual chocolaty brown colour (almost as wheat/straw colour) using Genovese Super Brazil beans.
Does anyone have any suggestions or proven methods to correctly calibrate machine and grinder as I still think there is still room for improvement but unfortunately I have fallen into a rut and am not sure what next to change to achieve true espresso greatness.
Thanks all.
Doug.
