cheers guys, am very happy with the results ad the machine is an absolute pleasure to use, and produces a great cup. My other thought was if it would be possible to incorporate the shot buttons, onto the group head like the strada has, though am thinking the cost and mods involved wouldnt warrant such a mod
John I say — Leave some room for the human factor KK
well i finally finished customising the la marzocco gs3. Moved away from timber and had some custom billet aluminium pieces made for it. The coffee machinist machined the side panels and were anodised in electric blue, and specht design made the new group cap, but i didnt like the look of the flat standard ones, so had it made to look like the strada AV group caps. Portafilter handles are from pesado. The only other thing i would like to do is change the feet to some taller S/S ones This one will now be a keeper, as cant see myself wanting or ever needing to upgrade for a long while
Wow great looking machine and nice custom modifications!
Never seen one of those in the flesh What’s the make and model ? KK
Claims to be made by 'Calandra & Co Pty Ltd', 240v 900w, cat no CXE9 Yes, it was marked as working (but with usual warning tag on the power cable that it is not tested). Doesn't seem to be a true espresso machine. I think it just heats the water up and steam pressure drives water through the head when you open the valve. Not something I need, but an interesting curiosity
Thanks It resembles a Bellman coffee maker But with a portafilter KK
I just happened to come into that model just two months back (and moved it on since). Was planning to use it as a portable steamer but was too bulky for that purpose. Both you and KK are right. It's a Bellman-style moka-pot coffee maker, with electric element (~1000 watt) and a thermostat. Interestingly there is also a thermostat-bypass button presumably for extra oomph when steaming. The advantage I see is that you can make multiple cups of coffee, compared to conventional moka pots where you only get one try. Load the portafilter (takes about 14-15g, 54 mm tamper), open valve, pull a moka-shot, close valve, reload, pull another moka shot, rinse and repeat until the water runs out. The brew temperature can get quite high like a conventional moka pot so no surprise there. Very powerful steamer - almost too powerful. Given its age, I was surprise it still works and quite well at that. And a nicety is it's made in almost full stainless steel construction (with the only exception in the shower screen which was made from your usual moka pot aluminium/alloy).
Thanks Brett! Don't think I've added my espresso machine photo to this thread (in fact I haven't posted here for a bit... :P) My pride and joy and my daily driver (the lever that is). And no, orange is not my favourite colour (in case you were wondering why it has the same 70s orange as the Calandra above). :rofl: Both the machines did come from 70s though!
Wow. That machine is a real beauty and it’s good to see that you have a very serious grinder there. Wow again for that grinder. What a brilliant setup.
Here’s a La Marzocco GS3 happy pic from one of my Melbourne customers. That’s home coffee machine heaven.
i like the artpresso side panels, i think the only other thing these machines need to finish off the looks are some nicer and slightly taller stainless steel feet
well i finally finished customising the la marzocco gs3. Moved away from timber and had some custom billet aluminium pieces made for it. The coffee machinist machined the side panels and were anodised in electric blue, and specht design made the new group cap, but i didnt like the look of the flat standard ones, so had it made to look like the strada AV group caps. Portafilter handles are from pesado. The only other thing i would like to do is change the feet to some taller S/S ones. This one will now be a keeper, as cant see myself wanting or ever needing to upgrade for a long while
have been away for a while... that's just stunning John! Wow :thumb:
