Lacehim had the same experience as I did, in that I have never been able to get an equal pour from both sides of the group handle. My routine evolved to being: half fill the basket two settling taps on the bench fill (I have a Cunill Tranquillo grinder, so it is 2 X timed doses to full, with settling taps between doses) a "polish only" tamp with an Orphan Espresso close fitting tamp As far as the false pressure bleed, I let it come to full pressure on the gauge, when the light turns off, then bleed, which normally takes the gauge back to about 30% pressure and I can see steam before it begins heating again
