in Vic it is all pretty simple. The PFIT (premium feed in tariff) was always planned to be an interim measure to encourage early adopters with a cut off date, or capped number of installs, whichever came first. Anyone installing solar could choose either the PFIT or the SFIT (solar feed in tariff), now that the cap has been reached, the PFIT is no longer available, so the choice is between the TFIT (transitional feed in tariff) or the SFIT, which is not capped. those already signed up remain on PFIT until they move house. I don't know, but it is possible the Queensland change affects real payments for those who are net power exporters? That is the way things are moving here in VIC, although the current VCEC (Victorian competition and efficiency commission) recommendation is for a govt MINIMUM of $.06 - $.08 per kwh, PLUS whatever the householder negotiates with their retailer. In VIC this is all net feed in of course so only affects excess power generated, the effective rate remains 1:1 for power generated and not exported. All clear now? edit: a couple extra points, in Vic if you add extra panels, the pfit ends as it was designed to quickly build to a set generating capacity which has now been reached. pfit for those on it runs until 2024. the tfit is 33c (25+8) not 25c. AGL currently pay 68c/kwh. - jonty you may want to change supplier
