I have been asked too many times. Can I use a dimmer to control my Vibe pump or other device.
SHORT ANSWER: Dimmers are not all the same. Some act as a restive load OTHERS modulate the frequency. Both will dim a standard incandescent lamp, as that is what they have been designed for.
I would not ever even consider using such a device.
LONG ANSWER:
Vibe pumps usually don't need high current but it is not that simple as just any dimmer AND what works for one or some where else in the world, may not work for you. (Voltage and Frequency are often at play).
A vibe pump is a combination of FREQUENCY ( that is what drives the rate of pulsing) and VOLTAGE which to some extent provides the magnetic force (That defines the force that the slug can exert). Thus the one way valve/springs/ size of plunger and rate of cycling is all involved and the interaction between all variables is interesting.
So depending on how much control and what level of detail, a dimmer is at best a simple sea anchor in a storm. Some effect can be had; maybe more subjective than objective BUT better than nothing. Then again what size/type sea anchor ?
Further more, on a few examples all I see is mismatched electrical items, poor workmanship and electrical safety totally out the door, all for a bit of what ? Sorry, not worth the risk and little to be gained.
Where as when it comes to medical and lives at risk, proportional control-valves with feedback AND note: the valves and controllers cost more than many coffee machines. However the accuracy / linearity / and consistency is there to be had and often critical to the outcome, see the vid at about 2min.
In effect a OPV that could be PID controlled
http://youtu.be/5jspoB6_YuI
