Well I think I managed to dial in/season myself with the SJe now. I haven't weighed whats going in or out as I am using a scoop to load the beans into the hopper. On to setting the dose, I'm using the double button and then editing it's programmed time after each shot. I want to get it to the point where it finishes grinding the beans but keeps going for about another second after that so there's nothing left behind to go stale. I think I'll measure in and out on the next one and see how much I am losing. I gott this grinder assuming the quality of the grind would improve (from Smart Grinder), knowing it would be big and hoping it would be faster, quieter, and cleaner - the timed dosing would just be a bonus that I could play with. Now that I have had a good play with it I am happy with it's speed and if it get's even faster I won't complain. I'm not sure how loud some grinders are but this sounds tolerable for my in-home use. I have an open kitchen with the loungeroom adjoing and I can now hear the wife talk and the TV with the grinder running... I had to raise my hand to signal to her that I couldn't hear everytime I used the Smart Grinder. The extra speed offsets the noise the SJe puts out anyway. I am wondering if it will get any quieter with a smaller hopper or with no hopper at all - I'll have to try. Is the SJe clean as expected? NO. The speed at which it throws the grinds in to the PF mean some can end up on the counter - 10-15% or thereabouts. I've tried two ways to combat it. First, I ran the grinder over two doses with a light tap on the bench in between to settle the grounds. This improved but didn't cure the situation and I want to use the PF holder and use the time grinding to get milk from the fridge - multi-tasking at it's best! Second, I ate a Creme Caramel (yum), cleaned the tub and sliced the bottom off to make a funnel. Problem solved but it looks crap having a white plastic tub sitting on the bench next to this grinder. I'm looking around for a better solution. As to the quality of the grind, well I'm far from an expert and I'm learning a new machine at the same time and using VST baskets just to make things even trickier but I think the grind quality is good. It does clump a bit but less than the Smart Grinder did and overall the result is much fluffier and appears very uniform in size. I fired up the EM6910 again and pulled two shots to compare the Smart Grinder and the Super Jolly and then did it with the BDB too and the winner is clear. Not saying the SMart Grinder isn't exceptional value for money - I believe it is. But I'm glad I took the jump 😃
