Went to supercheap, asked for a hone. They looked at me blankly and then said, ahhh on of them, and said go to Repco! 🙁 Anyway SUCCESS at last in the lusso antivac department. Fumbled around with various parts, but this is what worked. Remove Safety valve and replace with a 1/8" M-M Fitting attached to the boiler where the safety valve sits. On top place a 1/8" female T, on the rear end I fitted the safety valve (which is 1/8") and the other end pointing towards the front a 1/8"M to 1/4"F, then attached a Elbow fitting 1/4"M-F, and then fitted a 1/4" Antivac. I couldn't find any candles so I used a old film camera case, cut down, to contain any spraying water. The lid sits on the top of this, and should stop any spray hitting the electrics. The electrical cover needs modified, but only to take out a part of the brace so that it can be bolted back in. Shouldn't cause an issues. Here's some photos. 🙂
