Springbok wrote:
So after all this how does the Breville match up to the Rancilio Rocky? I have a delonghi kg100 ( $180) ( no sarcastic comments please - Im a stove top person) which has been pretty good - but am thinking of upgrading and buying a Sylvia - do I really need a new grinder to go with it?
I've continued to use the Breville without incident. As AM will attest, I grind way, way too fine and could probably get away without the single thinnest-possible shim I have in there. Anyone who says they can't grind fine enough is someone most likely using stale supermarket beans. I've had no further troubles - but I've not had to grind under-roasted beans since either. I'm happy with the Breville. As to the Silvia - they're a de-facto standard for the serious single-boiler crowd, but there are better machines out there for the money. You can't get my Bezzera BZ09 in the country any more, but the construction of it leaves the Silvia for dead, particularly in the temperature stability stakes. I'm also thinking of upgrading, so might be persuaded to sell.
