1…468910
  • on 1318324499:
    Hi AM, it's expensive but only a fraction of it's value when finished...  At the end of the day, for me this one's a keeper and will be used at home for our daily coffees, so I don't mind putting the time and $$ into it.  If it was only for resale, I could have done it a lot cheaper and not bothered so much with half of the stuff I've done.... Sometimes I tend to get carried away a bit with my resto's  ??? I'm also selling off the Cimbali 2 group, and a nice tax refund to pay for the expenses..... ;)
    What an incredible journey. Thank you or sharing it thus far!
  • on 1318330938:
    Glad you're enjoying it...  It would be great to see some more resto's underway.  I like to see these old timers brought back to life.  ;D
  • I feel that I own part of it for helping with your questions Its like helping you, to give this special Urania a new breath of life So I hope I am permitted to have imaginary coffees from your descriptions when posted Why do I feel young again  :D KK
  • on 1318336598:
    So I hope I am permitted to have imaginary coffees from your descriptions when posted KK
    If ever passing through Adelaide, everyone is welcome guys to drop in for 'real' ;) coffee's from the new (old) machine.  cheers.
  • This afternoon I got busy cleaning up some of the ceramic bits.  These pieces are the socket and plug for the power lead running along the rear cover to the light. Speaking of lights,  I thought it was too much stuffing around with placing the ballast for the fluoro, so I returned it and picked up an incandescant light that comes already with a fitting and cable. Anyway here's the plugs after cleaning.  The cockroaches certainly ate well, judging by the amount of crap I cleaned out of the back of the socket.... IMG_2171.jpg IMG_2164.jpg Check out the insulation - I think it's leather!  :o IMG_2166.jpg IMG_2165.jpg One of the machine feet had the sole surviving rubber insert.  It's convex on one side.  I'll start looking for maybe a sink plug or similar,  and cut to fit.  If nothing turns up,  maybe I'll just get some flat rubber sheet from Clark rubber and cut to size. IMG_2170.jpg IMG_2168.jpg IMG_2169.jpg
  • on 1318418011:
    An imperial rule.... I say that's an Imperial rule.......  :o Or A duel rule  and it is it 37mm  ???
    Yep, imp on one side & metric on the other.  37mm it is  :)
  • Those or similar rubber feet are available They are known as dome feet You can also get large grommet type feet and modify pushinfeet_lg.jpg Solid rubber blocks can also be turned on a lathe However I would be getting rubberized cork and paint them black  I have some industrial rubberized cork if you want some KK
  • Thanks KK.  I also found these from an australian company.  There should be something here; just needing the length cut to fit. http://www.chairtipsaustralia.com.au/round-internal-plastic-chair-tips.html Maybe Round Internal Chair Tips, or Rubber Chair Tips, cut to 37mm. rubber_feet.jpg
  • Rubber chair tips if diameter is available would be good Easy glides may also be suitable http://www.chairtipsaustralia.com.au/easy-glides.html KK
  • Fantastic progress Borat Makes me feel like I'm dragging the chain a little
  • You might need to build that borat.  You'll need another project, your nearly finished that one!  Must be a record rebuild!  Not that we are complaining.. it's been a great thread to watch.  We might even have to organise a social event when you get it finished! :)
  • Hmmm, tempting, but my hands are pretty full right now, and the bank balance pretty low ;) There's a Lambro (needs resto) going cheap as well...
  • I signed off on the artwork for the digital glass printing today.    The colour will have more of a gold tint to it though.. artwork2.jpg
  • WOW, amazing working and at lightning fast speed! I can't wait to see the before and after photos side by side. What grinder will you have on the bench next to this beauty?
  • Good question...    Nothing yet.  I might have to get something modern, in the meantime to tide me over whilst looking for one to resto. If I could find one (unlikely), without paying a ransom (even more unlikely), then one of these would be nice to make a matching pair..  [the one on the left] 2939568.jpg But more likely, I've been sniffing around for one of these, which I think is a good match too... 5526727.jpg
  • KK, yep, that one's been relisted a few times.  1500 euro's is a bit optimistic....  :o Unrestored I've seen them starting at around 300 euro's.  :)
  • So where's the Lambro?  Where do you find these things?
  • The lambro's on Ebay france. Just keep looking.  It all pops up sooner or later somewhere in Europe.
  • A quick question for the electrically non-challenged....  ;)  Are two piece heating elements normally wired in series? My old 1500W element has the bars running horizontally (A-B, and C-D), and a jumper connecting one leg of each (B-D).  I dug out the multimeter and if I add together the resistance of each bar individually (A-B, + C-D), it equaled the resistance measured from the non jumpered terminal of each bar (A-C)  confused?  ??? Here's a pic of the old element, and a simple wiring diagram....  Any coments?  (and yes it will be checked by an electrician) IMG_2161.jpg wiring5.jpg
  • on 1318674564:
    WARNING !!!!! DO NOT GET ANY OF THOSE TERMINALS WET  !!! SAY AGAIN. DO NOT GET ANY OF THOSE TERMINALS WET  !!! A: 1500W and 1500W at what rating ? B: What is the impedance of each one and in total..
    Hi AM,  the 1500W is total.    The baseplate has 900W stamped on one side, and 500W on the other.  Everything is still in parts at the moment, so no chance of anything getting near power just yet... :)  It was only partially soaked  (lower than the baseplate) in citric acid to clean up the scale.  I have a new element to replace the old one, as the copper is corroded in places and I thought it was likely suspect anyway. Measuring the old one: Impedance of the 500W is 94, and the 900W is about 55. Total across both was 150 Update edit:  The new one which has slightly different element length measured 95, and 50, and is supposed to be 1500W. And here's a clearer pic of both the new and old: IMG_2172_2.jpg
  • on 1318675428:
    I hate to say this But 900W + 500W = 1400 W KK
  • Yes yes KK, I failed primary school maths.....  ;D  ??? I forgot to clarify that the old one was 1400W, the replacement is 1500W because that's all there is....  Unless a custom job which is $$$.. PS.  My 3mm, 0.5 pitch bolts arrived today: IMG_2179.jpg :'( :'(  Think they might have shipped me 2.0 or 2.5  by mistake.. I've also been looking around for 1/4" hard drawn copper tube, so I can make up a new fitting for the pstat.  Seems to be rarer than hen's teeth..  Could probably use the soft annealed stuff from aircon / refrigeration but I prefer the firmness of the hard drawn.
  • Here's an updated wiring diagram.  It turns out the element should be wired in parallel. wiring6.jpg
  • on 1318680334:
    You just need to know where to look  ;) http://www.cranecopper.com.au/sizes/astmb88.asp KK
  • Thanks KK.  Here's another one for you...  ;D Anyone know an Australian supplier for chromed flexible gooseneck tubing?  I want to use a couple of metres of it to carry the power cord. Something like this: Flexible-Metal-Tubing.jpg
  • on 1318765449:
    Most of that hose comes from overseas However the best and most economical solution is to use stainless steel braided hose Would a household under-sink type flex water hose work for you 02c91fdd-487d-4bf0-9b7a-de52b404cd5c_1.jpg Or you can try this link http://www.ferret.com.au/c/Radcoflex-Australia/Corrugated-Metal-Hoses-Hose-Assemblies-and-Wire-Braid-by-Radcoflex-Australia-p22373 KK
  • Thanks KK.  I'm trying to keep it the same as the original which I'm told was also used on the matching grinder.  Here's something similar I found (the middle one): http://www.triflex.com.au/index.php?cPath=118_234_213 SS-Conduit--Fittings1.jpg Waiting for confirmation on sizes available (limited availability if you're only buying 2 mtrs...  :( )
