So I've finally made it home. Even tho it's late-ish (new parent. Anything after 8 is late now) I couldn't resist the lure of playing with my new machine.
First of all, It's clear that only considering the width of the machine was probably an oversight:
Wouldn't have stopped me tho. ;D
But the main problem really is the lack of a manual. Chris is chasing one up, but still, this German version isn't hugely helpful, even with Borat123's kind help with translation.
First attempt, the grind wasn't coarse enough. Decent crema, short pour and a good puck but lacking slightly in flavour.
I dialed down the grind quite a few notches and got what was a bang-on extraction - about 30ml in 30 seconds and crema all the way through. However, I got a bit of water leakage down the outside of the portafilter. The pressure gauge didn't seem to move tho and I've looked at the pictures on the manual since - the portafilter handle might not have been tight enough. I had it dead centre, the manual has it to the right of centre.
The pressure gauge is now sitting just below '2', even tho the machine is off. It's not resting on the little plastic 'peg'.
Not sure how to proceed until I get some feedback tho.
I've realized what a difference a good tamper makes also. So much easier with the new one, but it's so heavy I accidentally fractured my second puck. I also need to be aware of the dose with this group - the shower screen is low enough that even a couple of ml below the top of the basket is full enough to prevent the portafilter engaging. That's not the one that caused a problem, BTW, I got rid of that one without using it.
All in all, looking forward to laying more tomorrow!
