AngerManagement wrote:
That I do not have... Just have some odd bits or every thing and nothing about. The issue is, that if other items might be required.... Then consistence will be an issue.....
AM, I would be happy with whatever you come up with. The other handles etc are all black which I'm thinking to leave original at this stage. Re the rod, to end up with a thread that will fit an M4 nut, do you start out with 4mm rod, or something a bit larger? I'm thinking of buying a small section of 4mm 304 stainless rod, then getting it bent into a right angle and tapped with a thread. One side would be 25mm and the other 35mm. Do think the SS would be ok for tapping by hand? thanks.
