Woohoo. Fitted. Only need a small sand with a file (bought a small triangle one from bunnings). I didn't think they where on far enough, but then realised that the tap was screwed out and the square section started a few mm further out. Doh. At least I didn't keep sanding! lol So I just put them on, screwed in the stock screw and bob's your uncle it all worked. The size is perfect, just a smidge bigger than stock but much better for grip. The lusso HW & Steam taps need a good hard turn to keep them from leaking. Just the design of the taps from what I've heard. Anyway, take a look and see what you think. Personally I love it. I think I have the only fully tricked out PV lusso with custom handles & taps in the world! 🙂 ;D 😃 8) Big thanks to AM for making it all happen. We need to find you a big pile of wood AM so that you can make more of these. They really are fantastic.
PS. There are no endcaps yet, I've decided to make my own s/steel ones because the you have to drill a hole in the stock ones to get the tap off! 🙁
